Old 03-09-2019, 12:11 PM   #13
jaykay
jaykay's Avatar
The theory on the DOF is the lack of lubrication causes heat build up, leading to galling and failure. As the dual row has twice the contact area, the heat build up in the bearing should be both faster and to a higher temp, which should be leading to its failure sooner than the single row. But that is not what happens in the real world, were single rows fail at a rate near ten times that of dual rows.
Yes all good thoughts but I am not sure a dual row would produce more heat, or critical heat levels because there are more points of contact. Friction is driven by “normal” loading of one element against another and in the case of a dual row one can argue the loading is split between two bearing assemblies. Normal loads are lower at each yielding lower friction forces perhaps below critical levels.
Having said all of this I am of the opinion that poor brearing design is a main factor and that no amount of lubrication in a rolling element bearing will circumvent an overload condition
986 00S
