Old 03-08-2019, 09:01 AM   #10
Homeoboxter
The two products are based on different technical premise's: The IMS Solution is based upon the long proven bearing design used in the air cooled turbo engines, the DOF is based upon the questionable premise that "it is not the bearing, it is the lack of lubrication". The reason this is questionable is that if it really was the lack of lubrication, the dual row bearing with twice the bearing surface contact area should fail more frequently than the single row, "due to a lack of lubrication", which is exactly counter to reality.....
It’s actually the opposite, since the bearing wear is twice as fast in the single row because of the double load compared to the dual row. So the single row starts pitting much sooner. DOF would make sense if the failure was the result of lack of lubrication. But that’s not the case in a bearing that’s swimming in oil all the time.
