Old 03-07-2019, 04:55 AM   #3
brainles71
If the gas tank is 1/4 full or below you could fill it up and run it dry (till the fuel light comes on) or just dump the gas depending on your confidence level.
Dump the oil and filter before you try to start it up again. For safety purposes you should do the brake fluid as soon as you can.
brainles71 is offline   Reply With Quote
