Old 03-04-2019, 01:19 AM   #1
YellowS2000
Your post is confusing. Is it the side marker bulb, or a bulb in the headlight?
No matter...
Fuse A3 = right side markers.
Fuse A4 = left side markers.
Swap fuses. If no change, also check headlight connector pins.
Sorry yes its the buld in the headlight. In the UK we do not have side markers only the side indicator.
Its the small bulb in the headlight unit that is activated by the first turn on the headlight knob. In the UK we call that the side lights
I have sprayed WD40 on the connector pins
Peter
YellowS2000 is offline   Reply With Quote
