Old 03-03-2019, 04:50 AM   #11
Frodo
Originally Posted by Elmer View Post
The torque value for the LN magnetic drain plug is 19 ft/lbs, not much past a good finger tight. Most of us are used to changing the oil in our Ford/Chevy and cranking down on the steel plug into a steel pan. I use a beam torque wrench to put my LN magnetic plug in as I know that I'd twist it off or distort it so that it would crack.
Bingo.
Survey sample size just doubled to two.
