Old 02-28-2019, 12:55 PM   #14
JFP in PA
Originally Posted by dmonk View Post
No, I haven't tried removing the cap while idling. So if my AOS has failed, shouldn't I have a check engine light or something?
Not necessarily. The optimum method to test the condition of the AOS is to use a digital manometer attached to an old oil fill cap. Warmed up, the system should read 5 inches of water or less; if it reads higher, or you read pressure, it is toast.
