Old 02-26-2019, 07:32 PM   #1
jmitro
jmitro's Avatar
bad grinding in corners
99 base 2.5L, 5spd manual with 120k miles.
in tight corners with heavy throttle I hear a bad grinding noise from the rear end, like dragging steel pipe over a concrete floor. It does not happen with light throttle or in long sweepers.
I don't see anything obviously binding or grinding. All suspension pieces are brand new. I'm thinking the most likely culprit is a bad CV joint (boots are clean, no grease leaking) or maybe a bad wheel bearing (they don't seem loose when I rock the wheels with the suspension unloaded).
any other thoughts?
07 Porsche Cayman S speed yellow
87 Porsche 924S Carrera GT project/ 951 engine transplant
2015 BMW X5
jmitro is offline   Reply With Quote
