Old 02-25-2019, 01:29 PM   #10
Frodo
Hey, they grow alfalfa in the infield of my local track (RPM). Sometimes it needs harvesting.
Nice of you to oblige them (though hopefully only infrequently ).
I got to looking at the specs for the filter I’ve been using (51042, on the right below) vs the one stevedOx linked (51348):
I noticed that his specifies a value (8-11 PSI) under the section labeled “By-Pass Valve Setting-PSI” whereas the one I’ve been using indicates “None” in that space. I don’t really pretend to understand a lot of this, but does that “None” indicate a lack of bypass at start up (ie a good thing)? And that my setup with the 51042 is preferable to that with the 51348? Or am I totally off-base on this? Educate me, please
