Old 05-14-2004, 12:32 PM   #5
Lartymarf
Ad Sach,
Thanks for the response.
I'm new to this board and this board doesn't have a very high traffic, but the responses are all quality responses!
You said... "The older Boxsters are experiencing about the same problems (outside of convertible top cables) compared to the newer Boxsters, so they seem to be holding up fairly well."
Are the 2002 and earlier Boxsters prone to convertible cable problems? My other concern was about the plastic rear window, is it easy to see them crack? I read some other posts here and also on roadfly.com Boxster forum and there seems to be some posts recently on their top not working properly or the rear plastic window cracking and separating from the top and dealer charging and arm and a leg to replace the entire top, like they do not fix just the plastic window portion.
Thanks,
Jimmy
Lartymarf is offline   Reply With Quote
