Old 02-24-2019, 08:16 AM   #4
Cunningr
Cunningr's Avatar
Originally Posted by Elmer View Post
I used Hertz for dash and door speakers.
There's quite a bit of information online (RennTech, CAI, and this site) on various solutions. As you don't have the MOST system, your installation has a few more options. IMO after replacing the head unit, the amp has to be next. There are several multi-channel amps that you can use. I used Kenwood head unit and 5 channel amp. Dash speakers are Hertz 4 in coax, Hertz woofers in the doors (5.25 in) and then had the drivers in the rear deck sub changed. I used Morel 5.25 in there and then mounted the Hertz tweeters where the Bose tweeter were. I'm very happy with the sound and installation.
I would suggest speaking with Rod at CAI. He's easy to talk to and a wealth of information.
+1 for CAI bit pricey but solutions work as advertised so worth it.
Are you sure those subs will fit under the seats? My problem is heighth so behind the seat impossible.
Cunningr is online now   Reply With Quote
