Old 02-23-2019, 12:40 PM   #15
Turbodad
Originally Posted by Byrnsey2 View Post
My 2004 Boxster is doing the same today!
No sound coming from the fuel pump but also no Amps from fuel pump fuse (so my roadside cover person said)
Where should I start??
My problem turned out to be a weak "positive" ground in the engine compartment. It was rusty, and if I wiggled the cable and turned the key the engine would start. Disconnect the battery. It is located in a black plastic box next to the power steering reservoir. Use a screw driver to pop the box open and a 14 mm socket to remove and clean the nut.
2001 Base with 2002 3.2 DIY swap 97 "short shift" tip "Joe Toth" aerodynamics, Z top, painted headlights.
2001 Boxster 5 speed
Turbodad is offline   Reply With Quote
