Old 02-21-2019, 08:45 AM   #16
Starter986
1998 Boxster Silver/Red
If the water pump has not been changed, its one of those "While you are in there" things.
It also makes it easier to change the motor mount.
You may want to put in a low temp thermostat as well. You don't need to replace the thermostat housing.
A good place to buy the WP and thermostat is (ware house 33 auto dot com) (remove spaces) Put RENNLIST in the discount code place and you get an additional 10% off
+1
I changed my water pump when replacing the motor mount. It made reaching those WP bolts at ~2 and 4 o'clock ridiculously gravy. Definately a "while you're in there".
1998 Porsche Boxster
