Old 09-25-2006, 05:57 PM   #17
bigislandboxster
SD987 makes an important point. '98's were not supposed to have tires bigger than 17". Modifications had to be made to the suspension , as it would put undo stress on the suspension system. If these changes in the suspension were not made when the previous owner installed them, you may be flirting with disaster....I'd ask him what he did prior to putting those rims on , as you may have problems in the near future if he hadn't....The 19's seem to make the car too high in my opinion, the wheels aren't bad, but not my personal preference...
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
