Old 02-20-2019, 05:57 AM   #2
husker boxster
husker boxster's Avatar
Welcome & great looking Boxster.
If this is your first Porsche, you'll find parts are going to be expensive, esp compared to Japanese cars. No need to throw $$$ at stuff that doesn't need replacing. Change the oil. Inspect the serp belt and replace if it looks cracked. Change plugs and coils if you don't know their history. Then save a $1000 for the items that will crop up that you didn't expect. Many items will give you a hint they're failing - the water pump will drip and you'll smell antifreeze, the AOS will leave soot in the exhaust tip and will consume a bit of oil, etc. If this is not your daily driver, you should be able to catch these items as they start to fail and fix them on your schedule.
1989 928 S4 5 spd - black
