Old 02-18-2019, 08:29 PM   #1
BoxMann
Originally Posted by KevinH1990 View Post
Check with your department of motor vehicles. They may have a suggestion. In Virginia a car buyer can purchase a permit to drive a recently purchased vehicle for a few days without plates. I understand that is not exactly what you need and that NY laws are likely to be different. They may have a process that would work for your situation.
NY DMV does issue an In-Transit tag so you can drive the car home either within or outside the state. But that's after you've already bought the car !! That's not the problem here. If/when I decide to buy it, it's not a problem, I don't need temp or in-transit tags, I can go to the local NY DMV office and get permanent plates. (The Seller is also in NY)
The issue I raised in the OP is, prior to making a buying decision, how do I test drive the car, and how does the PPI shop test drive the car if the car has no plates on it, it's not registered, and it's not insured?
2004 Boxster S, 6 spd, Triple Black
1986 944 Turbo (sold in 1988)
Since then, a 300ZX, a few BMW 3 Series, a few VW's
BoxMann is offline   Reply With Quote
