Old 02-17-2019, 01:02 PM   #7
particlewave
Pull the start lock relay out, then insert a jumper wire between pins 30 and 87. Turn the key to start. If it cranks, the issue is likely with the DME/security lockout. If it still won't crank, the issue is likely the starter/power.
