Thank you particlewave. This is my second switch...both did the same. Will call provider about getting a third replacement. Tested all fuses by the pedals and all were good. Starter is not that easy to access to tap on. Is there any relay or fuse that I am missing? In reference to double checking my work, once you figure out how to fit under the tight space, it is not difficult to do. You remove the screws, disconnect the "bad" switch, replace it for the new one ("good one") and then you insert it back on. Then tighten the screws back. I did noticed some grease on coming from the mechanical part of the switch where the electrical connector inserts. Will see about uploading a picture if I can
