Old 02-14-2019, 12:22 PM   #15
Oldcarguy
Oldcarguy's Avatar
Originally Posted by Quadcammer View Post
that silicone application is WAY WAY WAY too thick on the left side of the pic. You likely have a bunch of that silicone floating around now or will shortly.
The right side is much closer to what you are looking for.
also no need to silicone on the outside of the bolt holes since the pan gets sealed on the lip to the inside of the holes
thnx QC. Because it’s on the left side I should be able to lift the flap with a pick and check with the scope to see how much went to the inside. It will not take much to reseal it if necessary (I haven’t put oil in in yet).
Rgds, Fred
