I had an Optima yellow in the car for a while until the negative post cracked off the battery. Decided to go with an Odyssey - but a regular sized battery as I have had a PC925 before in a different car and it wasn't very reliable. My battery was also mounted in the front in the trunk by the previous owner for better weight distribution.
I also have been using a BatteryMINDer Model 2012-AGM: 12Volt-2 Amp Battery Charger Maintainer/Desulfator for Odyssey, Optima and AGM Lead-Acid Batteries. I had a regular battery tender before, but this unit is far superior for AGM batteries. I would highly recommend this for any AGM battery.
