Old 02-11-2019, 05:33 AM   #15
husker boxster
husker boxster's Avatar
Originally Posted by BoxMann View Post
I have some additional info on the car and maybe someone can help me with this.
I understand that the car has "H&R Springs, RSS Billet Aluminum LCAs, monoball ends and spherical bearings"
I know the LCAs are for camber adjustment, but can someone tell me what the rest of that means?
Also, there's a note there that says these upgrades are "causing slight MVH". Don't know what that acronym is or what that statement means.
Thanks.
Monoball ends replace the rubber bushings I was referring to in my post stating things wear out and cause alignment issues. They attach the LCA to the body. Spherical bearings are also a rubber bushing replacements in the LCA. Both items tighten up your suspension compared to their rubber counterparts. Look at tarett.com for examples.
These items tend to stiffen the ride, which leads to NVH - noise, vibration, and harshness. I don't have the H&R springs, but I do have the other 2. Yes there is a bit stiffer ride, but not unbearable. I drive my CSS in winter, which should exacerbate the issue but I find it barely noticeable.
To paraphrase Seinfeld, whatcha got Georgie boy, is a track car.
1989 928 S4 5 spd - black
