Old 02-09-2019, 09:05 PM   #11
eee
Just replaced the fuel pump and the fuel pump relay, no change . The car still has the same symptoms.
Here's a video of the attempted start after replacing the pump: https://streamable.com/hg4ky
I'm going to over my work for the third time tomorrow and make sure I didn't miss any connections. One thing I'll double check is the orientation of the inlet and return lines on the sender unit, I may have mixed those up as there's no indicator.
Edit: I did mix up the inlet and return lines from the pump to the sender unit. Fixed the orientation, double checked everything and buttoned it back up. Still no dice.
eee is offline   Reply With Quote
