Old 02-09-2019, 09:13 AM   #1
Sergio
Ignition switch replaced...now won't start
Hi, Ignition switch was acting up on my Boxster 98 so I replaced it. Turned the key on, all the lights lit but the engine did not turn.
I read that there is a fuse that needs to be tested (will do that next). If that fails, will test voltage going to the starter. Are these good troubleshooting steps or should I start somewhere else?
Sergio is offline   Reply With Quote
