Old 02-07-2019, 05:33 AM   #2
robdelorenzo
The people on here know what they are talking about (myself excluded) listen to their advice, they are here to help. I have to agree that the leak you are experiencing is way more significant than what I had. The drain hose for the coolant tank is found up under the passenger rear tire. You will see a short stubby hose that is open on one end if you remove the tire. It took me a while to figure out that's where the coolant was coming from. With the help from here, I followed the hose up to the small drain hole in the top of the coolant tank. From there, it was either the caps leaking or the bleeder valve. Stick with it, the coolant system only has so many parts, it's sealed and under pressure so finding the source of the leak will become apparent.
robdelorenzo is offline   Reply With Quote
