Old 02-05-2019, 04:25 PM   #10
DoninDel
NewUserName
Originally Posted by eee View Post
Borrowed a friend's multimeter to check the fuel pump fuse today, it was fine. Also checked the 12V rail for the fuel pump relay and the fuel pump resistance, both seemed fine. However, I couldn't hear the fuel pump running when the relay or a jumper where in.
I've ordered a new relay and fuel pump, and I'll see if those do the trick (in that order). If that doesn't do it, I'm thinking it's the CPS.
Why CPS? I don't think you would've gotten spray start to fire with a bad CPS.
Sounds like fuel pump to me (you said you tried jumping relay with paper clip).
We'll see....
DoninDel is offline   Reply With Quote
