Old 02-04-2019, 03:03 PM   #10
Greg Holmberg
Here's a summary of the pre-purchase inspection from BR Racing, in case you find it hard to read in the photograph.
  1. One wheel bearing should probably be replaced.
  2. Car has stock brake rotors not the slotted or drilled ones.
  3. Front brake pads should be replaced.
  4. Rear brake pads are fine (60% left).
  5. Car does not have the extra radiator in the center. (Not really necessary unless you live in Texas, in my opinion).
  6. The end-links on the rear sway bar are stock (not adjustable). You probably want to get the adjustable ones from Tarrett.
  7. Rear sway bar is not connected (I did so for a wet day I ran).
  8. Missing one of the plastic underbody panels. (I think these are about $100).
  9. The rear lower control arms are stock. You'll probably want to replace these, you get about 1/2 a degree more camber. I don't know the cost.
  10. There's a way to connect the rear lower control arms to lengthen the wheelbase 1/4" or so. It's a minor improvement, but you might as well do it since it doesn't require any new parts.
  11. Driver's seat was manufactured 12/2012. It will need to be replaced or have a back support created for it.
  12. Seat belts expire in 2020.
  13. Fire bottle was not in the car (I left it at home).
  14. The fire system on switch is next to the driver's leg and could get flipped off accidentally. Should relocate it.
  15. Battery is stock (heavy, 38 lbs).
  16. Wiring in the car is stock. You can get lighter-weight ones with fewer wires.
  17. There's a spare tire in the front trunk.
  18. The cable for the battery cut-off switch--they don't like the way it's routed. They think it would be too hard to pull. Personally, I had no problem pulling it.
  19. Body damage.
  20. Car has a passenger seat installed.
  21. Stock shifter on risers.
  22. Parking brake is still installed.
  23. Has stock hood releases front and rear. You might like to have hood pins installed.
  24. Has wheel studs.
  25. Has a quick release on the steering wheel.
  26. Windshield wipers are still installed.
  27. Roof not on car (I left it at home).
  28. No roof net (I use arm restraints).
  29. Has catalytic converters still installed. Straight pipes would get you about 5 more HP.
  30. Needs a rear tow hook.
Greg Holmberg is offline   Reply With Quote
