Thread: RMS Issue
Old 02-04-2019, 10:41 AM   #6
Homeoboxter
That`s an easy fix. I`d just remove the sharp edges using sandpaper while covering the gap with a piece of cloth so the dust won`t get in. Then I`d just use curil-t or similar to seal the seal. If you do this, make sure you don`t touch the crank surface with the sandpaper where the seal-lip rides on.
