Take off the gas cap and listen while someone turns the ignition to the ON position. Do not turn to the starter position. You should hear a whirring noise from the fuel pump in the gas tank.
No sound, check the fuel pump relay first. If it is good, then the fuel pump might be bad.
3X Water Pump, Clear side markers, Crios Mod, Front engine mount, Flywheel, clutch, RMS, AOS, MAF, serpentine belt, power brake vacuum line, battery, 2X CV boots, Fuel filter, Oil filler tube, 3X ignition switch, 90K service, gas cap
