Originally Posted by brybart
I've recently replaced all four O2 sensors, disconnected the battery to reset ECU, after drive cycling and driving for 108 miles no codes, and in Durametic everything shows ready except for secondary air injection. I can activate the SAI pump in Durametric and I can hear it run. Do I need to drive a little more to get the SAI to ready status? Most of the information I've seen stated it switched to ready after 100 miles. But if I have to drive some more I won't be too upset  . Please let me know what the next steps could be?
Is there a CEL? I had a CEL and check SAI with Durametric and the motor was running. Ultimately we found that the Y pipe in the vacuum lines was blocked by some debris. All fine now.
