Old 02-01-2019, 04:50 PM   #1
lowpue
lowpue's Avatar
Hi All,
I will soon get to start reassembling the engine and it is still a bit unclear for me why the valves were touching the pistons. This makes me wonder if my IMS gears are still aligned and not rotated with respect to the shaft. How can I test this? Also, since the IMS is out now, would it make sense to pin the gears?
Thanks for any input.
I had a new(rebuilt) engine put in my boxster. Gear slipped and we thought the chain skipped a tooth so the timing was fixed. Then it did it again so the shop took a closer look and the IMS gear was slipping. It was sent back to the builder who pinned it. If yours is slipping you need to fix the timing and then pin.
2020 Taycan Turbo S - DD Rain
2015 Huracan - DD Sun
2002 Boxster - Play Car
2000 C2 Aero - Track Car
1965 Dodge Coronet 440 - Nostalgia
lowpue is offline   Reply With Quote
