Thread: Is this bad?
Old 01-30-2019, 10:31 AM   #10
Blackroot
looks like a crack at the bottom of the cylinder? perhaps just more broken piston? regardless, need for new sleeves and to deal w big chunks of metal flying around the bottom end. my price was premised on bad crank as stated in the post. i was also talking Cdn $; presume you understand that, although called 'dollars', they are not the same as american $. yes, you may be able to 'shop around' for better pricing, but should avoid confusing shopping around with doing things half-arsed, such as only sleeving the damaged cylinder, filing the burrs off the crank and slapping it back in, etc.
$5k is a good price, newart should take it quick.
Fair call
It is always easy just to assume everything is broken and spend way more than necessary.
That was my only point.
Break it down and analyze parts individually.
I think all of us would really love to see what's inside
Blackroot is offline   Reply With Quote
