Thread: Is this bad?
Old 01-30-2019, 10:28 AM   #10
The Radium King
The Radium King's Avatar
looks like a crack at the bottom of the cylinder? perhaps just more broken piston? regardless, need for new sleeves and to deal w big chunks of metal flying around the bottom end. my price was premised on bad crank as stated in the post. i was also talking Cdn $; presume you understand that, although called 'dollars', they are not the same as american $. yes, you may be able to 'shop around' for better pricing, but should avoid confusing shopping around with doing things half-arsed, such as only sleeving the damaged cylinder, filing the burrs off the crank and slapping it back in, etc.
$5k is a good price, newart should take it quick.
