Thread: Is this bad?
Old 01-30-2019, 09:49 AM   #11
The Radium King
The Radium King's Avatar
Originally Posted by Blackroot View Post
No, your costs are way off the chart.
OP, shop around
exchange rate here: xe.com but paypal and credit card much less
op posted the cost of his core at $1500 cdn already.
nickies are $5k usd here: https://lnengineering.com/products/watercooled-cylinders-pistons/36-911-nickies-inc-96mm-fsr-je-piston-set-inc-rings-pins-clips.html
$2k usd for crank was from previous post.
you can gamble on ims bearing (note the results in this thread if you lose that bet) but vendor here has bearings averaging around $750 usd, not to mention tools and other bits that will have to be replaced.
not off on my costs whatsoever. feel free to back up your statement and prove me wrong. not sure you can however, given that op posted a pic of a cracked cylinder and you advised in post #5 to replace the heads ...
Last edited by The Radium King; 01-30-2019 at 10:02 AM. Reason: don't forget customs, 5% fed tax, 10% provincial tax
