					Originally Posted by boxxster  What did the install involve? Also do you have the take the console out to remove the armrest? |
The armrest portion is simply the cover. It has 8 t-hex bolts that hold it to the frame. Open your console, remove bolts... Lifts right off. You must remove the factory vinyl cover by peeling it off and then scraping, pulling or whatever method to get the foam and old adhesive off. 3m 90 spray contact adhesive for regluing. The hard part is getting everything lined up and then folded down and properly laid down around the edges and underside. The piece is precut and fits well, but is pretty thick at the seams. One of my seams is a little off to the right in the pic. Not sure if I over stretched that portion or if that is just a bit off from the company. It is hand stitched so it’s possible it was a bit off to begin with.
