Thread: LED high beams?
Old 01-28-2019, 11:48 AM   #9
Lrobb1215
https://www.amazon.com/Aukee-Headlight-Lumens-Extremely-Conversion/dp/B07FRC77GX/ref=sr_1_2_sspa?s=automotive&ie=UTF8&qid=1548630240&sr=1-2-spons&keywords=h7+led+headlight+bulb&psc=1 I purshcased these and everything works fine. Plug and play but I cannot get the brights to work. I replaced my stock bulbs (high and low beam) with these H7 LEDs. So 2 on each side. But when I try to turn my brights on, the indicator light on the dash comes on, but the lights dont change at all. Is this because im running 2 LEDs on each side? Should I run a low beam LED and high beam halogen or vice versa? Any suggestions will help, thanks.
Lrobb1215 is offline   Reply With Quote
