Old 01-27-2019, 11:17 AM   #11
jaykay
jaykay's Avatar
Originally Posted by Quadcammer View Post
So stock intakes are off. Bit fiddly but really no biggie. Fuel lines i think will be a non issue. The plenum will clear the 997s oil cooler. Vac line is a trivial change.
Drilling...well, it aint gonna be fun qnd im gonna have to move alternator and ac compressor i think, but ultimately if i mark well, center punch, and use drill block properly it should be fine. Prolly gonna end up with a right angle drill.
Finally, id be amazed if the cayman cover clears. These plenums are seriously high. I may need to lower the motor about .5"
Happy with progress so far
Would be able to measure the entry diameter of your plenums and post it?
986 00S
