Old 01-25-2019, 04:23 AM   #3
flouese
flouese's Avatar
There are tools for removing them, but who has the time for that?
I just use a small flat head screwdriver (jeweler) inserted into the slots on either side of each pin. Insert the screwdriver into one slot at a time and pry inward (toward the pin) to flatten the barbs.
This applies to the main connector.
For the other smaller bulb connectors/sockets, I just cut the wires close to the connector and solder on new wires, covering the joint and any exposed wiring left on the connector with heat shrink tubing.
Thanks,
I'll give it a try this weekend.
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
