Originally Posted by osw986
I removed the plastic rear wheel protectors and cleaned them up . I want to paint but what is the recommend finish and type of pint I should use to keep with orginally finish ?
I would guess semi-gloss to flat black, most durable you can find.
My problem is the little rubber trim piece on the bottom falls off eventually, so I buy a new one.
