Old 01-20-2019, 08:28 PM   #1
seningen
seningen's Avatar
If the motor cranks ok, the battery is fine. Eliminate that from your possibilities. When the battery is toast it will not turn over with the starter. Period.
Now to the issue. Several possibilities:
1. Failed/intermittent ign switch. A very likely possibility
2. Failed crank position sensor. Maybe but usually once they die they will never start again.
3. Failed/intermittent fuel pump.
4. Failed/intermittent ECU
Change out the ign. switch first if you can't clearly isolate the problem. Cheap and reasonably easy.
Switch good and swapped
Cps good, scoped signsl at dme
Fuel pump works, no gnd signal from dme to relay
ECU good, starts another car all day long
No spark
No fuel injector signal
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
