Thread: What now?
Old 01-20-2019, 08:29 AM   #2
maytag
Who's askin'?
maytag's Avatar
Originally Posted by bob4a3 View Post
Thanks Maytag,
Don't know for sure the code is real. No hissing and no gas smell. No trouble filling with gas.
I used a smoke machine and can't find any leaks. I reset the code and it comes back as soon as the system tries to pressurize. CEL then comes on after code is set three times I think.
I checked that purge valve and canister valve work properly.
If there's no hissing when you release the gas cap, that suggests the fault is real. If your system isn't vapor-tight, then there's a leak somewhere. As to how to find that..... you've already done what I would do: smoke it.
Did you smoke it from a single source? ie: one side of a check valve but not the other? I'm just thinking out loud here. If we know the tank isn't pressurizing, maybe build a cap with a fitting that you can hook the smoke machine to. I'm just thinking trying it from a couple of different places.
Otherwise, I'm no help. I'll be watching with interest and hope someone smarter than I chimes in.
