Old 01-18-2019, 05:01 PM   #11
Javelin
Originally Posted by phook View Post
Javelin, do you plan to change out your brake hoses? If so, are you going to go with OEM or OEM equivalent?
When I bought my car and got a PPI, I was told that the brake lines look like they are still original, which means at this point they are about 19 years old. I want to change them out, and the cost of SS is not much more then buying an OEM equivalent like ATE and OEM is more expensive then a set of SS lines.
I've tried searching around but there isn't many threads on this topic. I thought yours might be the best to ask this question since you are trying to stay in stock class and I know SS lines will bump you up.
I am not planning on replacing the brake hoses at this time, but if I do have to I will have to use the OEM style rubber/PTFE versions. I have used SS lines on other projects, including track day cars, and never needed them nor got any actual measurable performance advantage from them. That said, can't hurt either.
2000 Boxster S - SCCA CS / PCA P03 autocross build
YouTube - PlaysWithCars
Javelin is offline   Reply With Quote
