Old 01-18-2019, 05:58 PM   #2
rick3000
There Is No Substitute.
rick3000's Avatar
How long has the hardtop been on your car? Does it squeak excessively? You can adjust it using the bolts to get a "tighter" fit, which may help it be more water tight.
Are there any noticeable gaps anywhere? Have you ever treated the seals with Gummi Pfledge? The seals could just be old and not "sealing" as well as they should.
You can adjust the entire top using the bolts which would probably help most with the seal against the front/windshield, you can also adjust the window tracks which is much more annoying to do. I have written about this before, here's how I adjust the top using the bolts:
Adjusting the hardtop is important to help reduce exessive squeaking and/or wind noise caused by poor fitment. I repeated this process several times the first few weeks after I installed my hardtop, as it was settling to my car. I also repeat this process when I reinstall the hardtop if it has been off the car for an extended period.
Inside the hardtop on each side, just above the spinlock levers there are two plastic covers that pop out to reveal three hex head bolts. To adjust the hardtop, secure the A-pillar clamp, then loosen the hex bolts on each side of the top. Have an assistant push forward and down as hard as possible on the hardtop, and tighten the bolts on each side. You may want to lock/unlock the spinlock levers while doing this. Repeat as necessary.
