Originally Posted by ohioboxster
Actually is there a difference between pre-cat and post cat 02 sensors?
Nope. The only difference in the original ones is the connector plug on the end of the sensor. If you look up the Bosch universal sensor for Boxsters (about $100 ea) the same part number is for pre and post cats. In fact, any 4-wire sensor that physically matches the screw threads should work fine.
