Old 01-15-2019, 06:50 AM   #11
phook
Javelin, do you plan to change out your brake hoses? If so, are you going to go with OEM or OEM equivalent?
When I bought my car and got a PPI, I was told that the brake lines look like they are still original, which means at this point they are about 19 years old. I want to change them out, and the cost of SS is not much more then buying an OEM equivalent like ATE and OEM is more expensive then a set of SS lines.
I've tried searching around but there isn't many threads on this topic. I thought yours might be the best to ask this question since you are trying to stay in stock class and I know SS lines will bump you up.
phook is offline   Reply With Quote
