Originally Posted by Homeoboxter
Yes, the bore size both for the 2.7 and the 2.5 should be 85.5 mm, so rings listed for the 2.7L should be ok for the 2.5L, unless I`m missing something else.
You should measure the cylinder bore's for wear, if they are worn beyond spec you should probably reinstall the original conforming rings in their original positions.
