Old 01-08-2019, 09:34 AM   #7
BYprodriver
BYprodriver's Avatar
Originally Posted by marsheng View Post
Generic answer.
Is there pressure buildup from the engine case breather, if not, rings are probably fine.
If the car is for high RPM, a slightly larger gap is ok as very little gas/air gets through the gap a such a short time.
Hasting Rings says 0.014 " per inch of bore.
I'm sure there will be after market rings for sale. Most ring widths today are roughly the same for similar size pistons. I haven't stripped a 986 motor but I presume they are nikasiled, so get compatible rings. Ie not for cast iron.
I have a 2.7 motor in the shed just waiting for some spare time to give it a full overhaul.
There is no nikasil in any 986 engine.
