Old 01-07-2019, 12:09 AM   #55
Smallblock454
No, because when you drive the car there is no constant oil level in the engine (acceleration, braking, corners). The oil is swapping around in the engine oil pan and in the engine. And the hotter the oil is, the more it swaps, because of the lower viscosity. Also when the engine runs oils level is also not constant, because the oil pump circulates the oil and the oil is also "splashed around" (maybe there is a better term for that in english) in the engine.
Regards from Germany,
Markus
