Thanks...I see from searching this is a fairly common issue.
I think I will try the 2800 rpm rev up start in the morning.
https://www.renntech.org/forums/topic/49155-secondary-air-test-readiness-monitor-incomplete/
Maybe just a couple more cold start cycles is all I need...
the p1341 appears to be from the cam deviations. It has not triggered in quite a while. The cams are showing
Cam 1 -0.75
Cam 2 1.28
and have been for 100+miles. From what I have read these are well within spec. The car is running great.
