Old 12-30-2018, 07:54 PM   #1
seningen
seningen's Avatar
If you can pull the switch and have a multi meter, you can see which combination of pins shorts when the switch closes and is open otherwise.
If that works, then the switch is good. You can then probe the pins, should have 12v on one of them. If there’s no 12v, I’d check your fuses.
Idk if the switch controls latch directly or if there is a relay in the path.
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
