Old 12-29-2018, 05:46 PM   #4
elgyqc
elgyqc's Avatar
Originally Posted by barkinfool View Post
Nice car & posts! In your first post you mentioned puddle on passenger side. You also mentioned the drains were clear which is great. One problem I had was the drain panel had a tear behind / under passenger side roof, so it leaked into the passenger footwell. Another point of ingress is through the passenger door if the seal under the door panel has been removed. You didn't mention it in post #2, so maybe you fixed / found that already, but wanted to chime in just in case.
Thanks for the compliment. I have to take the top off to see if there is a tear in the foam drip pan, I think you are right about that. Sometime before the Spring that will be done.
Grant
