Old 12-28-2018, 02:03 PM   #13
Blackroot
Originally Posted by Blackroot View Post
I edited below, so here it was
Make sure the brake fluid tank is completely full
Also, start with clutch fully up, pump the bleeder tank to 22psi. get under car and open bleeder.
When air noise stops and a steady stream suddenly appears, tighten valve.
Get in car and try clutch pedal (fill the brake fluid tank first as it will have lowered)
Might be perfect right there.
If not, repeat
I tried the Pelican way with starting the bleed process with clutch pedal down and never had any luck, BTW.
Nothing against Pelican as they are tremendously valuable, and I source them for almost everything I do.
Up always worked for me.
Blackroot is offline   Reply With Quote
